nelbarn Posted December 16, 2009 Posted December 16, 2009 (edited) I select certain channels and find that I get no audio or video from them. However, if I then disable the audio/video in the view menu before re-enabling the audio/video, the channel begins to show. Is there any way that I could avoid having to go through this process, disabling and enabling the audio/video each time before the picture and sound come on? Thanks, Neil support.zip Edited December 16, 2009 by nelbarn Quote
nelbarn Posted December 18, 2009 Author Posted December 18, 2009 I've examined this problem further and it appears to happen when I tune to certain channels and the aspect ratio changes from the previous channel. I've tried to change some of the aspect ratio settings but that doesn't appear to make any difference. The only way to make the picture and sound appear is by diasbling and re-enabling the a/v. The changelog for version 4.1 suggests that this issue has been identified previously and a fix was found... "•Fix: EVR/aspect ratio change and PIP. Hopefully a solution for missing picture after a aspect ratio change and EVR." I'm using the latest beta version 4.3.1.45. Any assistance would be gratefully received. Thanks. Quote
