mniamek Posted December 17, 2009 Posted December 17, 2009 "Polish DVB-S operators give EPG encoded in the ISO-8859-2 (Polsat) and in ISO-6937 (Cyfra+). Unfortunately does not give information about encoding. Polsat is not suitable byte identifying coding. Cyfra+ gives the wrong marker.On the programs broadcast together we get different coding, both wrong. MythTV allows to specify the encoding, but only for the transponder, which is transmitted program (in eithelper.cpp). In this case it is necessary to specify the encoding to the network or the transponder from which the EPG has been received. I wrote an patch, which adds forcing iso-8859-2 and iso-6937, depending on the source transport and/or network id, not on TSID() and OriginalNetworkID() from existing DVBEventInformationTable. There is someone who had similar problems and have any comments? Maybe I am wrong to do? This new encodings: ISO-8859-2 for source network id 113 ISO-6937 for source network id 318 I post a patch next week if there will be no comment. best regards Wagabunda" i found this info on internet, perhaps this can help fix problem with polish epg? : ( Quote
