sperwer Posted December 20, 2009 Posted December 20, 2009 Hi I have a problem by getting my client pc connected to the server pc. (On the server PC DVBViewer pro connects to recordingservice with no problems) On the remote pc i get the error "no hardware available" when i start DVBViewer I added 5 UND devices and auto discovered the server with no indications of problem When i test recordingservice connection i get possitive result "DVBViewer Recording Service 1.5.0.31 (beta) (servername) In channellist i am missing the list fromthe server, do i need to copy this list manually? Sperwer
Gioxy Posted December 20, 2009 Posted December 20, 2009 In channellist i am missing the list fromthe server, do i need to copy this list manually?Yes, and most probably this is the cause of your problem... you have to peek the "channels.dat" from the server Configuration folder (go to "Help / Configuration folder") and poke it on the client Configuration folder...
sperwer Posted December 27, 2009 Author Posted December 27, 2009 Thx, solved however im not sure what did the trick Sperwer
