Przemek211 Posted December 26, 2009 Posted December 26, 2009 (edited) Hello. Maybe you registered that if we reset PC or would be something similar DVBV can lost settings (language and similar for directx etc.). I had this problem and I replaced configuration folder from backup, and everything was good. But now i see that i couldn't save a changes in channellist. I'm going to scan or do some changes in channellist. After save and normal exit of program i will haven't this changes. Other preferences are working correct and could be changed. I saw also that when i tried to do new support.zip, the newest version of supporttool shows that file was generated correct, but still i had file from old configuration (i used this configuration folder too for save informations after reinstall of OS). I had to to manually delete file and now file is generated correctly. Can I back good saving of my channellist or i must export my channellist and next delete configuration folder and add preferences manually? support.zip Edited December 26, 2009 by Przemek211 Quote
Przemek211 Posted December 26, 2009 Author Posted December 26, 2009 i think, i solved problem and everytinhg is good now. I just export channellist and deleted files like a channels.*** and I imported channellist on clear list. Now looks like everything works correct. Quote
