sperwer Posted December 27, 2009 Posted December 27, 2009 Hi i have a setup consisting of a server and 3 clients. One of the clients is located at the server. The server has 2 Hauppauge HVR-4000 DVB-S2 cards and one Skystar2 USB. Tuner one: SAT A, B, C and D (channel group A) Tuner two: SAT A, B, and C (channel group Tuner three: SAT A (channel group C) What I like to do is: Being able to setup favorit list on clients an freely select channels on tuners not in use. What i am experiencing: Client1 has priority to the recording service When I connect seccond client DVBViewer gives the message"Channel redirected requested by Service" and then client2 is redirected to the same channel as client1 which is repeated if i select any of the favorits on client2. However if I on client2 select the channel from the channellist it change the channel as ordered. The channellist on client2 is copyed from the server (client1). I hope You can guide me in the correct direction. Sperwer
