RobbyRally Posted December 29, 2009 Posted December 29, 2009 (edited) I guys. I' have a problem with standby an recording service in windows7 operating system. When there is a recording in action and i put the computer in standby involuntarily, the computer go in standby. In windows XP that used before, when there was a recording, recording service denied stanby. Thanks, and sorry for my English P.S I use the latest test beta 1.5.0.60 of recording service but also with the 1.5.0.31 occours. Edited December 29, 2009 by RobbyRally
raty Posted December 29, 2009 Posted December 29, 2009 Have you got "Allow computer to enter away mode" set in your power options when in multimedia is active?
Kommakul Posted January 17, 2010 Posted January 17, 2010 after some test seem to work Thanks I´m having the same problem. What did you do? Thanks Christian
HomerDK Posted February 13, 2010 Posted February 13, 2010 Have you got "Allow computer to enter away mode" set in your power options when in multimedia is active? Hi. Where do I change this settings? Can't find it anywhere in power options in Win7
patti Posted February 13, 2010 Posted February 13, 2010 Where do I change this settings?Can't find it anywhere in power options in Win7 Check this out: http://h10025.www1.hp.com/ewfrf/wc/documen...#c01837578_away
Matti Hanni Posted February 14, 2010 Posted February 14, 2010 I have problem too with rec service. I updated win xp to windows 7 32bit and after that rec service dosen't wake up from stanby when record is starting. Sorry my poor english.
juha2206 Posted April 27, 2010 Posted April 27, 2010 HI Matti, I suffered the same problem - Scheduler recording woke up my laptop with Win Vista from standby, but not my new Win7 laptop. DVB Viever and Scheduler setups were the same, so there must be some other settings different by default. After going through Vista related standby problems and replies in this forum I found the clue: check the Control Panel Power Setup options - and VOILA. At Win7 Power Setup there is many advanced power options: check Standby option - Allow Scheduled Wakeups from Standby: yes / no. Must set YES. Only with this setting Task Scheduler recording timer can wake up the PC from Standby and Hibernate states. And by the way, DVBViewer Pro works nicely with Win7 (much better than in my Vista PC)
