How recording a same show than can start in different hour every day o
defcon5
Hi guys
I dont know how I can timer a recording than is possible start in different time every day
Yes, I can add minutes after and before timer recording, but this is annoyed because.... How much time add?
Another case is the following:
I can programing a TV serie for every day, ok but.... If while Christmas time, this serie is not broadcasting for the channel ??? Dvbiewer record equally ....
Would not be better, recording TV program if exist in EPG?
Any idea ?
Thanks in advance
RecordingService would be the solution. It can search the EPG automatically and create timers.
Or you can use EPGPlus plugin to do the same trick.
Thanks guys
I´ll take a look to your advices
