athos Posted December 30, 2009 Posted December 30, 2009 I installed the Ver. 4.2.1 with XP Pro and, in the same PC, the Recording Service Ver. 1.5.0.31: all is well. In a client with W7 i have installed the Ver. 4.2.1 and, without having configured, i have copied the DVBViewer and Cmuv directory. I have created the settings according to the instructions and all work fine except the timer display in Win7 client. When i plan a recording from Win7 client or XP Pro client, the timer screen in XP Pro client display correctly but the timer screen in Win7 client not show nothing! Where i wrong? Athos Quote
Lars_MQ Posted December 30, 2009 Posted December 30, 2009 Most likely the wrong IP in den DVBViewer -> Options -> Recording Service settings. Quote
athos Posted December 30, 2009 Author Posted December 30, 2009 Most likely the wrong IP in den DVBViewer -> Options -> Recording Service settings. I am sure that the ip setting is correct. Quote
athos Posted December 30, 2009 Author Posted December 30, 2009 I am sure that the ip setting is correct. I tried to install XP on the client that was installed W7 and everything works fine. May be a bug in the recording service with W7? Athos Quote
Lars_MQ Posted December 30, 2009 Posted December 30, 2009 No, works with win7 without problems. Quote
Gioxy Posted December 30, 2009 Posted December 30, 2009 Please click here: Always follow these instructions. Otherwise no one can - or wants - to help you! Quote
