Sign in to follow this
Brolly
B2C2's raw stream converting
Brolly
Does any1 know how to convert B2C2 raw stream into MPEG-2 ?
Share this post
Link to post
peter
if you mean PVA -> mpeg2 , you should use pvastrumento , mentioned in this forum
Share this post
Link to post
Guest Michael
if you mean the DVB Stream then ist is equal to a MPEG2 Stream.....
Share this post
Link to post
Brolly
No, not PVA. B2C2 don't have capability to save stream to PVA. It's SS1/clones.
The raw stream i've got from B2C2 isn't (at least fully) compatible with MPEG-2.
So, i'm sure some conversion is needed.
Share this post
Link to post
Guest hackbart
i'm not sure if you mean transport streams. these fancy 188byte sized small packets with a 4 byte header and 184 byte data.
The card returns the same stream which comes trough transponder.
For more informations you should take a look at www.etsi.com. All informations i needed are from this page.
Cheers
Christian
Share this post
Link to post
Brolly
It ain't seems to go that way.
It looks like card returns only PES, not full TS.
I should get something like this:
47 60 00 10 00 B0 11 which is TS header (first 4 byte).
Instead i get this:
00 01 E0 00 00
This means that first byte 00 is cutted from PES, next two is id (always 1). E0=11100000 which is video stream, 00-00 means it's length is not specified or not bounded....
Share this post
Link to post
