Mr. Man-wai Chang Posted January 4, 2010 Posted January 4, 2010 (edited) I configured both the Recording Service (1.5.0.31 beta) and DVBViewer Pro 4.2.1.0. http://en.DVBViewer.tv/wiki/Recording_Serv...tallation_Guide However, the recordings were split into multiple 512K files. How could that happen? What mistakes did I make? Edited January 4, 2010 by Mr. Man-wai Chang
krasno Posted January 6, 2010 Posted January 6, 2010 I'm only guessing, but try to loook in Recording Service's "Service Options" program also called DVB Service under recorder, maybe you have marked the "Split Files After" option, and set it to 512? Also check in DVBViewer if you have set the same in Settings/Options/Recorder, not sure if that affects RS but you never know If not, then I don't know... see the attached file..
Mr. Man-wai Chang Posted January 11, 2010 Author Posted January 11, 2010 I have un-installed the Recording Service and re-installed DVBViewer Pro. As far as I could remember, I didn't set that "Split" option.
krasno Posted January 11, 2010 Posted January 11, 2010 I have un-installed the Recording Service and re-installed DVBViewer Pro. As far as I could remember, I didn't set that "Split" option. yeah.. think I'll end up doing that too...
