Problem with going to sleep mode
Przemek211
Hello, i'm using DVBV 4.2.1.0 + RC 1.5.031. If DVBV is working with audio and video my computer isn't going to sleep mode. It is only turn off screen and i can see that video and audio is also turning off. If i manually disable video&audio or exactly after this one, computer is going correct to sleep mode.
That's no problem, that's a feature...
If there is a client connected on RecService, no matter if local (same PC) or LAN, the Service will block shutdown/sleep...
even though the client is on Server-PC - it's still a 'client'...
Thanks for your reply. So, can i turn off this feature?
sorry, but there's no switch to turn off this 'feature'. It's a must feature.
