meditating_hamster Posted January 13, 2010 Posted January 13, 2010 (edited) Hi Everyone, I'm having some issues getting DVBViewer to work and would really appreciate some help :-) I'm running Windows 7 Ultimate x64 DVBPro V4.2.1.0 Hardware: HVR1300 Windows 7 MCE picks up the card and tunes all of the channels fine, but DVBViewer won't find anything though, whether I select Europe or UK(mendip), I am selecting Terestrial as opposed to cable or satellite. Tried an in in depth scan, frequency range is 50000 to 858000. What's odd is that the signal meter jumps to green every now and then as if it's finding a channel, but the new channel counter remains at zero, and the PAT/PMT/SDT only ever has the PAT in red. The hardware device is selected Hauppauge WinTV 88x DVB-T Tuner/Demod. I've spent two evenings now reinstalling drivers (tried the wintv site ones as well as the default windows 7 drivers, virus scanning, forum searching and re-installing DVBViewer with no joy :-( I've had this working before with a technisat skystar2 HD, but am not in a position to be able to do this at the moment to fully test the app with this card) Cheers :-) info file attached Board specs Intel Pentium e5200 socket 775LGA Gigabyte MB model ep45-UD3 chipset intel p45/p43 support.zip Edited January 13, 2010 by meditating_hamster Quote
meditating_hamster Posted January 14, 2010 Author Posted January 14, 2010 I also tested this with another app called TV source and it did the same with that, suggesting that it may be a driver issue. Not sure if windows 7 by default uses something other than BDA drivers, but if it did then it may explain why the apps can't interface properly with the card yet MCE can. The major bugger is that I don't have my original wintv disk to test wintv with it. I could try downloading progdvb but would rather not install loads of different software and potentially causing a mess of dlls and configs. Quote
Griga Posted January 14, 2010 Posted January 14, 2010 UK? Have you already tried: http://www.DVBViewer.info/forum/index.php?...st&p=238443 Quote
meditating_hamster Posted January 15, 2010 Author Posted January 15, 2010 Thanks Griga your a star!! :-) :-) Appreciate the fast response, your suggestion worked great Quote
