Card detected but no chans found ?!
themaster1
I just bouht a DVB-T card which is a usb stick actually (Nova-T HD Hauppauge) it works with the provided software (WinTv) but with DVBViewer it seems i'm in trouble currently.
In hardware the usb stick is well detected, no problem, however when i scan the channels i get nothing, zero.
How can i solve this: Do i need a transponder list like with dvb-s or use the group option (by the way what's this option about exactly ??)... or something else, you tell me ?
Your inputs are welcome
In scan channels, you must select Terrestric in Reception type, and in Transponder list you must select the transponder that match the country/region you live in
