defcon5 Posted January 14, 2010 Posted January 14, 2010 I use RS without problems, but I´would like comment a litttle issue with descriptions of recordings. Some recordings (may be with accents) in DVBViewer appair without descriptions, but in web interface I can see description correctly. A clue: I manage my timers with automatic timer and with 1.5.0.50 RS the description was correct Cheers
Lars_MQ Posted January 14, 2010 Posted January 14, 2010 Yes that's normal. the 4.2.1 can't handle the Unicode stuff.
defcon5 Posted January 14, 2010 Author Posted January 14, 2010 Yes that's normal. the 4.2.1 can't handle the Unicode stuff. Thanks Lars ..and .. Is this only for languages with accents? with english and deutchland language exist same problem ? future solutions? Cheers
Tjod Posted January 14, 2010 Posted January 14, 2010 future solutions? The DVBViewer Beta 4.3.x supports Unicode. http://www.DVBViewer.info/forum/index.php?showtopic=36446
defcon5 Posted January 14, 2010 Author Posted January 14, 2010 The DVBViewer Beta 4.3.x supports Unicode.http://www.DVBViewer.info/forum/index.php?showtopic=36446 Of course End of doubt Cheers
defcon5 Posted January 27, 2010 Author Posted January 27, 2010 Hi A few days ago, I´ve installed RS 1.5.77 and now appair descriptions perfectly. I use DVBViewer 4.2.1 not beta 4.3.x Was fixed in RS 1.5.77? Cheers
