besoul Posted January 16, 2010 Posted January 16, 2010 Hi guys. I'm really sorry to disturb you, but I have a really annoying issue with my subtitles. Actually, I can not manage them I mean, even if I try to change the color or the font, any of them is applied. (so I have some big pixels in my text, it's really awful). I also want to underline the fact that is not possible to save the changes made to delay in the subtitles settings. Here is a screenshot of what is happening on my computer: Could you please just take a look to my problem? Thanks in advance... Quote
besoul Posted January 18, 2010 Author Posted January 18, 2010 Anyone can help me to solve this problem? ? Quote
Lars_MQ Posted January 18, 2010 Posted January 18, 2010 DVB-Subtitles? You can't manage them, they are images embedded into the DVB-Stream. The broadcaster decides how they are displayed, precomposes and transmits them. The viewer only displays the data as it is sent. Quote
besoul Posted January 18, 2010 Author Posted January 18, 2010 Ahh! OK! Thanks! So, I confused with subtitles of videos... I didn't know why it was not applied, but now, I have my answer. Thx Lars_MQ for having helped me. Quote
IRa Posted January 19, 2010 Posted January 19, 2010 DVB-Subtitles? You can't manage them, they are imagesYou can't manage teletext subtitles either. (Selected font size is 24 and colour purple. No effect to subtiles with colour or size). Quote
SJK Posted January 20, 2010 Posted January 20, 2010 You can't manage teletext subtitles either. (Selected font size is 24 and colour purple. No effect to subtiles with colour or size). Works here. Try to disable teletext subtitles after you have changed the settings and then turn them on again. Quote
IRa Posted January 20, 2010 Posted January 20, 2010 Works here. Try to disable teletext subtitles after you have changed the settings and then turn them on again.You are right, turning them on / off makes it work. How ever font colour selection does not effect even with that trick. Quote
