uglyned Posted January 23, 2010 Posted January 23, 2010 Hi, Still trying to connect up a Pure Evoke Flow to the uPnP server so I can listen to more radio stations amd hopefully TV music programmes on the box. The Flow never used to even attempt to play streams but since a recent firmware upgrade it does. It just doesn't play anything. It should be able to play mp2 audio. I enabled uPnP logging and tried to connect and then made a support.zip which I've attached. Anything you can do? Thanks!
Lars_MQ Posted January 23, 2010 Posted January 23, 2010 Is it an audio only device or a "tv-box"? If a tv box then try tv channels first, because radio almost never works.
uglyned Posted January 23, 2010 Author Posted January 23, 2010 Thanks but no - audio only. I would have liked to pick up the extra radio channels using it and maybe if lucky connect to the audio streams of some musical TV shows. No big deal, don't waste any time on it.
uglyned Posted January 23, 2010 Author Posted January 23, 2010 I had tried that but made no difference. Maybe try again though.
