wmax Posted January 25, 2010 Posted January 25, 2010 Hi there, When exiting DVBViewer i get a message box: "timer file readonly!". I have tried to change/change back the properties of several files containing the text "timer" but without result. Please somebody give me a hint. support.zip Quote
wmax Posted February 1, 2010 Author Posted February 1, 2010 No reply yet. Maybe one of the developers could answer. The error message does not only occur at program exit but also when starting or ending recording service (without affecting recording itself). Many thanks! Quote
Gioxy Posted February 1, 2010 Posted February 1, 2010 The unique and right file you have to modify is the "timers.xml" you find in DVBViewer current "Configuration folder"; to go straight in it click on the relative item into DVBViewer "Help" menu... BTW, I've never find that file protected/readonly on XP, dunno other SO... Quote
wmax Posted February 1, 2010 Author Posted February 1, 2010 No more error messages! Thank you Gioxy. Note, however, that the error is trapped when the file property is set to HIDDEN. So the error message was a bit misleading. However, I am really a fan of your programme. Quote
Lars_MQ Posted February 1, 2010 Posted February 1, 2010 This is not a correct DVBViewer installation. Please install the DVBViewer with the setup again, the program will most likely not run stable in this condition. Quote
fiscio Posted January 23, 2019 Posted January 23, 2019 I also found, that file property "hidden" causes the failure. Quote
