Bad sound from Skystar HD2 in some channels
Gugul
Hi.
My Skystar HD2 makes an acute sound in some channels, not all.
Mainly in the fullHD channels.
Does yours do the same?
ty
Most likely a decoder problem. check your settings.
I guess the card itself? I heard this several times. Mine do fine for luck
Format your harddisc and do a new install and NEVER again touch a codec pack, they most likely make your DirectShow Subsystem instable. :rolleyes:
Other than that: google for AC3 Filter (or take a look into the DVBViewer Program group, the link is somewhere there too).
