Polish DVB subtitles do not work
Arrow
Well there are no subtitles. They are announced and you can select them, but there is simple nothing. Checked it with VLC - same result.
Thank you I found the problem. Will be fixed in the next beta. :)
  • 4 weeks later...
version 4.3.1.82 beta - everything worked ok :bye:
version 4.3.1.90 beta - no Polish DVB subtitles on the menu :bye:
Works OK with Finnish DVB subtitles but it shows only one line of teletext subtitles.
Yes already know, a bug introduced while changing the ttx engine.
