Guest DAvenger Posted May 6, 2004 Posted May 6, 2004 In case you missed this one ... RadLight OptimFROG DirectShow Filter v1.0.0.1 has been released compiled against the latest OptimFROG SDK (v1.100, 04/21/2004) added support for OptimFROG DualStream small bugfixes "OptimFROG is a lossless audio compression program. Its main goal is to reduce at maximum the size of audio files, while premitting bit identical restoration for all input. It is similar with the ZIP compression, but it is highly specialized to compress audio data" BitTorrent link Download "RadLight OptimFROG DirectShow Filter v1.0.0.1" Quote
Klausing Posted May 9, 2004 Posted May 9, 2004 Hmmm. I have an *.mpc Audiofile and i can't play it in WMP or with Graphedit... Quote
Guest DAvenger Posted May 9, 2004 Posted May 9, 2004 MPC is MusePack format. Install the latest RadLight (build 11, link is in my signature) or the standalone RadLight MPC DirectShow filter from here http://fileforum.betanews.com/detail.php3?...?fid=1068295881 Quote
Klausing Posted May 9, 2004 Posted May 9, 2004 with Your decoder http://developer.radlight.net/download/mpc...MPC_1.0.0.3.exe it works. Quote
Guest DAvenger Posted May 9, 2004 Posted May 9, 2004 with Your decoder http://developer.radlight.net/download/mpc...MPC_1.0.0.3.exe it works. Of course it does Quote
Klausing Posted May 9, 2004 Posted May 9, 2004 Do you know a decoder which can make mp3 from this file? (for my mp3 player) Steffen Quote
Guest DAvenger Posted May 9, 2004 Posted May 9, 2004 Mm, Graphedit? A module for RadLight which will let you transcode all kind of files is on our todo list. Quote
Klausing Posted May 9, 2004 Posted May 9, 2004 Would be nice if you could let me know.... Graphedit is a bit to heavy if you have a lot of files .... Quote
Guest DAvenger Posted May 9, 2004 Posted May 9, 2004 Then you could try foobar2k or dbPowerAmp ... I think these two players are quite a good encoders as well. Quote
Klausing Posted May 9, 2004 Posted May 9, 2004 I found Alive ! Sounds great what this tool can convert... http://www.mp3-wav-converters.com/ Steffen Quote
