remote double click
krasno
I use a Medion RF MCE remote (X-10) and it works, but I have to press all buttons two times before DvbV. reacts.
That goes for all functions including games in the OSD menu's
Anyone that have any idea why?
I have tried several x-10 drivers
have a nice day
have a nice day
hehe
I hope, the answer will not come to late.
Take a look at this page:
http://www.x10receiver.net/?setlang=en
This programm can be used for 31 days for free.
If you will try it, set under Options the keyboard default remote and clean alle Keaboard-shortcuts.
This programm will stearing the DVBViewer by itself. And if you want especilly Options for the DVBViewer, you can create all with you own Shortcuts.
I use it since 3 weeks and wrote sometimes to the support. They will help you, if you have some problems.
C.U.
No it is not too late at all :bounce:
Always nice when someone reply, to watch TV on a PC is not something easy..
And I sure fight many problems..
I'll try your suggestion ASAP.!!
Thanx a lot!!
