Picture in picture whilst playing movie/DVD
dvbrewer
At the moment, it seems to be the case that to use Picture in Picture while playing a movie/DVD you must first tune the channel/transponder and select preview before playing the movie/DVD. It would be a nice facility to be able to tune any TV channel or even radio in the PiP window whilst watching a movie/DVD and also have the facility to change to any other TV/radio channel or change between audio on the movie/DVD and the TV/radio channel.
Edited by dvbrewer
Only TV can be send to the PiP. You can only select the channel for the PiP in the Maindisplay, that are the restrictions. Any change would mean a freaking big rewrite of several key elements. Something which is not gonna happen. :)
OK, but could you not make it so you can launch a TV channel in a PiP window whilst watching a movie/DVD and be able to switch to its audio? This would be useful to check on news or sport for example.
How? And please a solution, that uses no extra keys on the remote control. and can be used in window and htpc mode. And is easy to understand. oh, and doesn't need a freaking big rewrite :)
How? And please a solution, that uses no extra keys on the remote control. and can be used in window and htpc mode. And is easy to understand. oh, and doesn't need a freaking big rewrite ;)
You could just have a setting to tick/untick in Options, that when you attempt to tune a channel while playing a DVD/movie it will launch a PiP window rather than stop the DVD/movie and show the TV channel fullscreen.
And what about that freaking big rewrite? I suppose this would require that rewrite: "You can only select the channel for the PiP in the Maindisplay". Otherwise I like your idea a lot as I think that I am responsible for giving the idea to this "PiP while watching a movie" -feature of DVBViewer :bye:
Edited by patti
And what about that freaking big rewrite? I suppose this would require that rewrite: "You can only select the channel for the PiP in the Maindisplay". Otherwise I like your idea a lot as I think that I am responsible for giving the idea to this "PiP while watching a movie" -feature of DVBViewer :)
I'm not sure it would really require such a big rewrite, since you can already get PiP while watching a movie/DVD, you just have to tune the PiP before launching the movie/DVD.
