Technisat CableStar 2 TV pci card
Stephkax
Hi All
I just buy this card and I'm trying to detect any channel on my cable network.
Is this card is compatible with DVBViewer Pro in windows 7 ?
No detecion for the moment.
Thanks for your response
St
  • 2 months later...
it works for me. My cable provider sends digital signal without special encoding (I mean there are stations available without Conax or other CI-cards).
I have Windows 7 Home Premium 64-bit.
Version: DVBViewer TE2 1.0.4.121
Regards,
T.
in case you mean the Cablestar HD2 i can also confirm it is working. I'm using windows 7 Professional x64 with the current Beta-Release of DVBViewer Pro. In my case (Germany) the channels are encrypted, so I also use an Alphacrypt CAM. Anyway I had to enter one frequency and the modulation manually in order to initially get all the transponders. I suggest you try to do this as well for your cable provider.
Regards,
Rag3
