Suuso Posted February 26, 2010 Posted February 26, 2010 Hi, I can not get sound from HD-channel. Channel is located in 122Mhz (6900, 256QAM). I checked from transedit that there are both audio and video streams. Video stream is h.264 pid.1900, audio stream is mpeg2 pid.1901. In channel editor, I can see that those pids are used. I can hear audio for less that 1 second when channel is turned on, then it disappears. I also tried to record channel and I didn't get sound either from recording. -Juuso Quote
Suuso Posted February 26, 2010 Author Posted February 26, 2010 Audio stream is mpeg2 and I can hear sound from SD-channels that also have mpeg2-sound so could it still be a codec problem? Quote
blasgl Posted February 26, 2010 Posted February 26, 2010 Install the AC3Filter and configure it in the DirectX options of the DVBViewer Quote
