bowa Posted March 6, 2010 Posted March 6, 2010 (edited) I have exactly the same problem as the post http://www.DVBViewer.info/forum/index.php?showtopic=39502 At startup DVBViewer 4.2.1 crashes with "Error in userdata" "Please install the DVBViewer with the correct data!". Running Windows 7 x64. I have been running W7 x64 Beta and DVDBViewer 4 for a long time without problems. I attach the supporttool logs. Machine is a Q9400 w 8GB mem, FireDTV tuner. BTW there are two important issues with DVDBViewer that should be corrected as well: Having to run DVBViewer as administrator is extremely bad practice. Its a serious security breach! Giving up with error message "Error in userdata" without pinpointing exactly what went wrong is bad programming practice. It would save both you and me a lot of trouble with an accurate error description. Thanks, Best regards Bo Wa support.zip Edited March 6, 2010 by bowa Quote
neograniceni Posted March 7, 2010 Posted March 7, 2010 This problem is typical for DVBViewer registered with blacklisted serial Quote
DeputyDawg Posted March 9, 2010 Posted March 9, 2010 I'm the OP from http://www.DVBViewer.info/forum/index.php?showtopic=39502 and I can assure you my copy is legit and so is my serial number. Still at least you took the time to reply, my thread has no respondees after nearly a week. In the meantime perhaps the OP of this thread would like to check out DVB Dream a program that actually does work with win7x64. Shame I had to, but hey I didn't buy a tv card not to watch tv. Quote
bowa Posted June 19, 2010 Author Posted June 19, 2010 (edited) I have a perfectly legal serisl and I'm willing to provide the Admin with a copy of your own registration email. As stated before, 3.8 and 4.0 installs and works well. 4.2.1 does not. Will you kindly answer in a respectful manner towards a fully paying client and provide details on how to solve this error? Bo Wannerberg Senior IT Manager Stockholm Edited June 19, 2010 by bowa Quote
