Codec necessary and audio extraction
tonylab
:) Hello, use the DVBViewer in order to visualize the programs through the SkyStar2. When registry I do not succeed to see the transmissions through Medium Windows Player. ^_^ Which codec I must install? I would want to know which codec go installs in order to make to read the recordings to you virtualdub? :) Finally, in order to extract the traces audio to filmati which the program I must use? ;)
Ciao, uso il DVBViewer per visualizzare i programmi tramite la SkyStar2. Quando registro non riesco a vedere le trasmissioni tramite Windows Media Player. Quali codec devo installare?
Vorrei sapere quali codec vanno installati per far leggere le registrazioni a virtualdub?
Infine, per estrarre le traccie audio ai filmati quale programma devo utilizzare?
Hmmm, thats realy crazy. Maybe they are aware the lots of downloads from this site and disabled the domain.
Try this http://divxstation.com/softwareId.asp?sId=213. There are two links. And at the bottom links to earlyer versions.
You can also download the ElecardPlayer Trialversion. This contains the demultiplexer too.
http://www.moonlight.co.il/cons_player.php
Steffen
