andresito Posted March 10, 2010 Posted March 10, 2010 (edited) Hi all. I have a problem in Windows 7 Ultimate x64, I can't see the channels in the selection tool bar inside the Internet Explorer window: What can be happening? And sorry for my bad english. Thanks. Edited March 10, 2010 by andresito
andresito Posted March 14, 2010 Author Posted March 14, 2010 (edited) I've reinstalled Windows Vista, both x64 and x86, and the problem is the same, can anyone help me? Before try it in Windows 7, it was running on the same computer with Vista x86, and worked good. Please, any idea about this issue? Thanks. Edited March 14, 2010 by andresito
Lars_MQ Posted March 14, 2010 Posted March 14, 2010 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210
andresito Posted March 14, 2010 Author Posted March 14, 2010 (edited) Thanks Lars_MQ, here it is the support file. support.zip Edited March 14, 2010 by andresito
andresito Posted March 15, 2010 Author Posted March 15, 2010 I have a new picture, the Recording Service apparently does not recognize the hardware, but in DVBViewer works fine and all DVB-T channels are perfectly tuned:
Tjod Posted March 16, 2010 Posted March 16, 2010 The Recording Service is not correct installed Pleas flow the Installation Guide http://en.DVBViewer.tv/wiki/Recording_Serv...tallation_Guide
andresito Posted March 16, 2010 Author Posted March 16, 2010 (edited) Thank you very much Lars_MQ and Tjod. I've installed the Recording Service one more time, following the installation guide, and it's working perfectly in W7 Ultimate x64. Thank you both. Edited March 16, 2010 by andresito
