Mac address mismatch
SHRIKE31
hello members
I just found this forum when I was looking for a solution to my problem
getting EOL to work.
Got the technisat skystar2 usb card on friday but no luck getting satsurf or
anything else to work(except dsl libary which seems to work)
When the oswizard runs I typed in my username and password and click
next, it then trys to connect to server but reports "mac address mismatch"
and I can go no further!
I tried to use the direct proxy as detailed on EOL site but after getting
"sat login succesfull" it just kept reporting 404 type error(failed to find server)
As a new member I would be gratefull for any help!!!
By the way, my signal level is 78% and I receive tv(m6,polish tv) perfectly
what says the EOL support for this problem?
It sounds the server (normal dial in connection) is wrong, because sat login was successfull.
BTW, IMHO you cant look tv and surf druing the same time via satellite.
Steffen
