xice Posted March 11, 2010 Posted March 11, 2010 X-Skin - Final Skin-Resolution : 1920x1080 (FULL-HD) Important !! Copy X.dll into the plugins folder The Skin run correct only with the plugin and DVBViewer v4.3.1.xx A remote-button must be created (ActionID 20001) to control through the skin. DVBViewer -> Options -> Input... Skin - Settings can be found in DVBViewer -> Optionen -> X-Plugin ... Download link HERE Quote
xice Posted March 16, 2010 Author Posted March 16, 2010 Update 7 OSD: Some modifications in the playlist OSD: Include MyMovies (mymovies.xml,mymovies_details.xml...) OSD: Changed the resolution of some images for a better OSD-Performance OSD: Fix some Errors in the recordings Plugin: Include playlist PopUp-Menu Quote
IRa Posted March 16, 2010 Posted March 16, 2010 Update 7Ever considered puplishing your skin in zip ? (so it could be tried without installing additional very rarely needed softwares) Quote
