Jörg Truchel Posted March 12, 2010 Posted March 12, 2010 Hallo ich habe versucht, nach der Anleitung den TV Browser mit der CMDline Plugin mit dem Recording Service zum Laufen zu bringen. Ab und zu klappt es eine Sendung zu programieren, aber meistens meldet der TV Browser Probleme beim Starten der Applikation. ----- Start of stacktrace ----- java.lang.StringIndexOutOfBoundsException: String index out of range: -1 at java.lang.String.charAt(Unknown Source) at util.io.ExecutionHandler.calculateParamter(ExecutionHandler.java:254) at util.io.ExecutionHandler.<init>(ExecutionHandler.java:82) at util.io.ExecutionHandler.<init>(ExecutionHandler.java:51) at captureplugin.drivers.defaultdriver.CaptureExecute.executeApplication(CaptureExe cute.java:248) at captureplugin.drivers.defaultdriver.CaptureExecute.execute(CaptureExecute.java:1 76) at captureplugin.drivers.defaultdriver.CaptureExecute.addProgram(CaptureExecute.jav a:130) at captureplugin.drivers.defaultdriver.DefaultDevice.add(DefaultDevice.java:214) at captureplugin.CapturePlugin$2.actionPerformed(CapturePlugin.java:231) at tvbrowser.core.plugin.ActionProxy.actionPerformed(ActionProxy.java:83) at javax.swing.AbstractButton.fireActionPerformed(Unknown Source) at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source) at javax.swing.DefaultButtonModel.setPressed(Unknown Source) at javax.swing.AbstractButton.doClick(Unknown Source) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source) at java.awt.Component.processMouseEvent(Unknown Source) at javax.swing.JComponent.processMouseEvent(Unknown Source) at java.awt.Component.processEvent(Unknown Source) at java.awt.Container.processEvent(Unknown Source) at java.awt.Component.dispatchEventImpl(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source) at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source) at java.awt.Container.dispatchEventImpl(Unknown Source) at java.awt.Window.dispatchEventImpl(Unknown Source) at java.awt.Component.dispatchEvent(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at util.ui.textcomponentpopup.TextComponentPopupEventQueue.dispatchEvent(TextCompon entPopupEventQueue.java:37) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source) ----- End of stacktrace ----- Was mache ich falsch? Gruß Jörg Quote
xarko Posted March 12, 2010 Posted March 12, 2010 Was mache ich falsch? Nun, da dies eine Fehlermeldung vom TVBrowser bzw. des TVBrowser-Capture Plugins ist, würde ich an deiner Stelle die Meldung zunächst auch im TVBrowser-Forum posten. Dann bliebe noch die Frage: Wie lautet denn bei dir die Parameterzeile fürs Aufnehmen und Löschen? Quote
