DVBViewer won't run
ml 05019
Ok, here's my problem.
I used to have DVBViewer 4.3.1.82 beta, as well as Recordingservice 1.5.0.91, on Windows 7 PC.
I recently created a new user on my Windows, and since then, I'm unable to start DVBViewer from under that username.
As you might know, when you unpack the DVBViewer beta files from a zip file, their permissions and owner change from "Administrator" to current username. So, the new account, even being administrator, did not have even "Read" permissions for replaced files. I did not want to edit all permissions manually, so I just reinstalled DVBViewer, unpacked 4.3.1.82 files over it, ran the program, and... I get
Runtime error 217 at 004AEDB9
followed with WER collecting crash information.
I suspect this happens because DVBViewer cannot read a file it needs - but I have no idea, which file. I already tried to clear DVBViewer folder in Program files and configuration folders in both Common files and current user's folder. What else should I clear?
P.S. Recordingservice works without problems, it's only DVBViewer that won't run.
P.P.S. DVBViewer still DOES run on the first username.
My system:
Mobo Acer AS5310
CPU Intel 2x1.66GHz
RAM 2GB
Graphics Intel 945GM
All latest drivers from Windows Update
Edited by ml 05019
Try starting the DVBViewer with Start -> programs -> DVBViewer program group -> support -> DVBViewer (Safemode). Does it work then?
Tried both safemode and debug mode. No.
