No "CyberLink Video Decoder (PDVD9)" selections in DVBViewer
ter9999
There are no "CyberLink Video Decoder (PDVD9)" video decoder selections in the drop-down lists in DVBViewer for both MPEG2 and H.264.
This is the best decoder after installatin the latest PDVD9 patch for both MPEG2 and H.264. And this decoder can be seleced in ProgDVB as you can see:
The "CyberLink Video Decoder (PDVD9)" decoder properties:
In DVBViewer, no the decoder selections.
Maybe DVBViewer and ProgDVB use different ways to retrieve decoders, hopefully we can get the CyberLink Video Decoder (PDVD9)" decoder for both MPEG2 and H.264.
Best regards.
you can get to the parameters after selecting the filter:-
press View button
filters
then choose thefilter you want to adjust and the parameters are shown.
hope that helps
Regards
Stu
Thanks a lot! After tweaking the merit, the new "CyberLink Video Decoder (PDVD9)" appears in MPEG2, H.264 and VC1 drop-down lists:
Edited by ter9999
  • Like 1
10031315340abfd75fea31ac40.jpg :D
Did you really get Cyberlink PowerDVD 9 H.264 Decoder to show up in DVBViewer?
Is it a trial version or a paid version
What version is it (click on PowerDVD in the upper left corner)?
..I can select even between 2 different cyberlink decoder :)
Ok, please state your PowerDVD9 version and version of the Cyberlink H.264/AVC decoder. This decoder should be invisible in DirectShow due to copyprotection and not usable by any third party software. So it is very intresting to know which versions you guys have, Cyberlink may have messed up applying the protection or somebody may have managed to remove the lockdown in some hacked version..
Edited by majstang
And IS IT A TRIAL VERSION or a paid version. And i am not interested in a hacked version. I am willing to pay for software, if it works. If nobody pays, nobody develop
  • 4 weeks later...
Hello
I have the decoder Ccyberlink v10 but the property of the decoder I have not these functions, why?
CG 4650 low profile with latest drivers installed
Winseven 32 bits OS
CM GA EG41MF-US2H
CPU Intel E5200
Try pressing (and hold down) the ctrl key when you open the filter properties in DVBViewer. Also google for cyberlink filters
(CLVD Pack and HD Pack 2.3).
Edited by ak2010
Thank you for your answer!
I already did this but without success!
