4.2.1 and CAM plugins
robena
With the 4.0 version, you have the choice to set or unset "Default disable AV" in the recordings options.
With 4.2, this option is no longer available, and in fact is always on, so that when DVBViewer is started by the Windows scheduler, the video is not displayed.
This has an annoying side effect: when you are using a CAM plugin to record encrypted material, the plugin is not called when there is no video displayed, and the recordings fails!
I would suggest to enable again this option with futur releases. Also, the CAM plugins should be used whether or not the video is displayed.
Aside that, great product!
§ 13
Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes.
Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not.
http://www.DVBViewer.info/forum/index.php?act=boardrules
