TeVii S660 DVB-S2 with motorised-dish
camane007
Hi there
I bought one " TeVii S660 DVB-S2 " and i've loosed lot's of time trying to configure it with my motorised-parabol (HH-100) with out any success.
I should be very grateful if someone have any manual to configure it.
Thanks in advance
camane007
  • 2 months later...
Hi Camane007,
did you solved your problem? if yes, how?
I have also a Tevii S660 with a motorized dish (supporting diseqc1.2) and Rotor Sat HH120.
DVBViewer and Tevii without the rotor works fine with DVB-s and DVB-s2 channels, but if i connect the rotor in between there is no signal level.
Thanks
AnotherDVB
