Stutters on H.264 1080i playback
Valts
Playing some downloaded .TS movies (Cyberlink decoder + dxva) and it can play fine for 20mins and then go stutter, drop frames, freeze. Then resume normally. Such never happens when playing same with media player classic (same decoders, dxva on).
Edited by Valts
  • 3 weeks later...
2 weeks gone by, would be great to have constructive feedback from devs.
check it with the beta. If you have problems there, you can file a problem report in the beta thread.
