AjeeB Posted March 16, 2010 Posted March 16, 2010 (edited) why I always locked to one DiseqC ! only hotbird while I have 3 inputs ... and everything ok with older versions? I search for 3 input's and get the 3rd input ! hotbird ! why is that? any explanation? and sometimes I lose hardware connection need to unplug USB and return it ! to get it works ttdvb-s2-3600 , windows 7 (32bit) , simple DiseqC 4 ports 1=nilesat 2=badr 3=hotbird 4=none tested 4.3.1.82 ... 66 ! before everything ok ! 4.3.1.60 works gr8 and best of all it's able to handle Skyitaly (HD) !! br Edited March 16, 2010 by AjeeB Quote
AjeeB Posted March 16, 2010 Author Posted March 16, 2010 same problem also with ... 4.3.1.90 any idea? Quote
Lars_MQ Posted March 16, 2010 Posted March 16, 2010 Please post some more information: http://www.DVBViewer.info/forum/index.php?showtopic=2210 Quote
AjeeB Posted March 16, 2010 Author Posted March 16, 2010 (edited) am sorry , here is it ! http://rapidshare.com/files/364220379/support.zip.html my computer is MAC PRO , INTEL quad-core (XEON) , 2GB RAM ECC , 2TB ,ATI radeon 2600HD - ..win7-32bit very stable hardware ! -\ plz solve this crazy diseqc ! problems Edited March 16, 2010 by AjeeB Quote
Griga Posted March 16, 2010 Posted March 16, 2010 We are looking after it... please try TransEdit (download from the members area). Set up DiSEqC for the relevant transponder lists on the left side of the TransEdit main window (don't forget to click Apply). Does scanning with TransEdit work? Quote
AjeeB Posted March 16, 2010 Author Posted March 16, 2010 hi, tested using transedit 353 - i do exactly what u said ! setup DiSEqC and apply ... then I tried to update freq. and it's ok ! scanning OK but why not work with DVBViewer br Quote
Lars_MQ Posted March 16, 2010 Posted March 16, 2010 As a workaround, just go DVBViewer programgroup -> support -> modify DVBViewer Pro and select the technotrend support dll and the "MS VC runtime libraries for KNC (4.1.1) and Technotrend" in the downloadsection of the setup. Quote
AjeeB Posted March 16, 2010 Author Posted March 16, 2010 (edited) As a workaround, just go DVBViewer programgroup -> support -> modify DVBViewer Pro and select the technotrend support dll and the "MS VC runtime libraries for KNC (4.1.1) and Technotrend" in the downloadsection of the setup. this is strange ! it's works ! after this update ty Edited March 16, 2010 by AjeeB Quote
AjeeB Posted March 20, 2010 Author Posted March 20, 2010 (edited) hi after solving my provlem with DiseqC ! and update ""MS VC runtime libraries for KNC (4.1.1) and Technotrend"" I can't handle freq. -- DVB-S2 (8PSK) -- is that related? to update ! this is crazy sometimes works sometimes not !! not stable ! any help? what u recommened ty br Edited March 20, 2010 by AjeeB Quote
AjeeB Posted March 20, 2010 Author Posted March 20, 2010 (edited) btw. I change DiseqC ! with new one same result Signal is 65% , TT-3650ci also there is freq. at nilesat 7w .. can't tune it ! 10834,V,27500,23,6,|OSN HD br Edited March 20, 2010 by AjeeB Quote
SpooZ Posted March 30, 2010 Posted March 30, 2010 Can also confirm this problem on the Technotrend Budget S2 3200. Works with last release 4.2.1 But if i update to latest beta 4.3.1.90beta or 4.3.1.82beta i can't get channels from LNB 2 Can't test any earlier versions since they are they have expired. Transedit does work fine. The above workaround downloading Visual C++ libraries don't work for me as i'm running Windows 7 x64 If i use DVBViewer4.3.1.82beta or DVBViewer4.3.1.90beta on my computer with Hauppage HVR4000 everything works. Hope there will be a release soon. Supplying the support zip. support.zip Quote
