sharp Posted March 16, 2010 Posted March 16, 2010 Hello I have just installed Windows 7 64-bit Premium instead of Vista. I have latest DVBViewer. I do not have picture. When I change channel the picture appear for a moment and gone immediatly. I ran regfilters. DVBViewer options shows codecs installed. What could be wrong. It is sure very simple but I cannot figure it out. I need your help. KR Quote
McenterFreak Posted March 16, 2010 Posted March 16, 2010 Why did you install 64 bit. Are you sure your drivers for your tuners support 64 bit? Quote
ter9999 Posted March 17, 2010 Posted March 17, 2010 Lots of users have migrated to 64-bit Windows. Now rare hardware don't have 64-bit driver. As long as the picture goes out for a while, the driver should be installed okay on the 64-bit Vista. You can try using "EVR video renderer" to see if problem's still there. Quote
Griga Posted March 17, 2010 Posted March 17, 2010 When I change channel the picture appear for a moment and gone immediatly. My guess is that switching the OSD off in the options will do something. Since sharp is ignoring "How to post problems/bugs correctly", blind guessing is all we can do. Quote
