perob Posted March 17, 2010 Posted March 17, 2010 Can You help me with this, what is the best video convertor for recorded stuff like movies or sports event in HD quality from .ts to .mkv extension? Thank`s in advance. Quote
Mister_M Posted March 18, 2010 Posted March 18, 2010 If you have H.264-recordings (HDTV) and you want to get MKVs without quality loss, you should use the combination of tsMuxeR (to demux the TS-file) and MKVtoolnix (MKV Merge GUI to mux the audio- and video-files to a MKV-container). Kind regards Quote
perob Posted March 20, 2010 Author Posted March 20, 2010 Aniother problem with this SW You said Quote
Mister_M Posted March 20, 2010 Posted March 20, 2010 (edited) Well, that's strange, I never got such message... I've read in another forum, that a user deleted the program, downloaded it once again and it worked fine. And you should also make sure to have enough disk space. Otherwise you should try tsRemux for demuxing (right-click the streams to do so). Edited March 21, 2010 by Mister_M Quote
