TransEdit: wonderfull tool - KMS Munich transponder file and channels
I just tested TransEdit 3.5.4 with KMS cable provider in Munich. I used the "old" transponder list found in DVBViewer and updated it with the transponder list I got from KMS last week (I'm now wired to their cable network).
I finally could find most of the channels they broadcast and save them on my desktop PC.
Here attached are following files:
- the ini transponder file I used to scan KMS cable (edited with TransEdit)
- the exported channel lists I'm using in DVBViewer (FULL and FREE channel lists)
As some may see, the FREE list has MORE channels than KMS says ;) (181 channels instead of 154 as stated in KMS adds; well, some payTV channels also broadcast some free channels that you can only find by scanning their own frequencies. Have fun watching TV!)
Stephaen
P.S.: replace "Stéphane" with "Munich" in those files to better remember...
UPDATE: FREE channel list now added... ;)
DVB_C_KMS_St_phane.ini
KMS_St_phane__full_.ini
KMS_St_phane__free_.ini
Edited by Stephaen
