PDVD10 unified video decoder in DVBViewer
ter9999
No h.264 codec shows up in DVBViewer?
Edited by buttonsNI.
just change the merit of the h.264 codec
what are you talking about .....in the new pdvd10 there is no h.264 decoder present in DVBViewer options...only mpeg2 decoder!!
with tools like the RAD LIGHT FILTER MANAGER you can change the merit of codecs. The codec with the highest merit will be used by a DirectShow Component. The UNIFIED Decoder of Cyberlink is not present in DVBViewer because the defualt merit is set to "do not use". You can change it to an otehr merit and then you see it in DVBViewer.
ok the one to change is called "CyberLink Video Decoder"
No need to set merit or register filters manually for PDVD10, after installation, there are the codec options in the lists.
I also had to change the MERIT value. After this, the decoder is visible in DVBViewer and works fine.
On my PC is also no H264, only the MPEG. But I use the latest Release, not the Beta.
in Powerdvd10 there is no dedicated H264 decoder. The "unfiied" decoder(with neither SD or h264 in the name) works for h264 and can be selected in DVBViewer if you change this decoders merit
Yes, the Merit Change did it, but i didn't have the Options as shown in the pic in thread #1.
press and hold CTRL when you open the properties, then you see more options
Could anyone explain what the difference is between SW, DXVA, and HAM mode in the miscellaneous options?
Can you store the settings in the Decimation, Decoder and Display sections of the extended options? Here it doesn't work. After rebuilding the filter graph they are always reset to "Good".
same here, but it's always been with those settings - powerdvd9, powerdvd8 & powerdvd7 ...
That's bad, because watching H.264 HD on my ol' PC (AMD Athlon 3200+, no DXVA available) requires setting Decimation = Auto or Decoder = Fast. I've tried to find the according (probably missing) registry entry with RegMon, but without success.
I have the same issue of settings not sticking for the DXVA option. I have a NVidia 8500GT so dxva should be an available option. Any idea how this could be enabled?
  • 1 month later...
  • 1 month later...
Hi,ter9999:PowerDVD 10 Ultra build 1714 has been published.
Do the codecs still work after the trial of the PowerDVD GUI has expired?
