Hauppauge WinTV Nova HD
Tripitaka
Hello,
Hopefully there is a good soul here who can help me set this lot up before I tear all my hair out.
I have a satellite dish which is plugged into the card, it seems to be receiving ok, I did get a spanish channel last night, I have installed the drivers from the Hauppauge installation cd but I haven't installed the Win TV software.
Found lots of codecs and installed them according to the included instructions and in my settings there is a codec for each requirement except for AAC audio, I have installed the AAC but it doesn't show up in the settings, it just states 'system default'
I scanned the astra 19 thing but all I get are spanish channels, the English channels all seem to be hidden, where are the English channels? Where are the HD channels?
It's a standalone pc, I am the admin. I have included the support file hopefully someone can point me in the direction of HD free to air English channels.
I was hoping this would be easy but there are SO many settings that us mere mortals get confused ;)
Kind Regards,
Tripitaka
If you want UK English channels you'll need to point your dish at (or scan) Eurobird / Astra at 28.2 degrees east. You seem to be scanning Astra at 19 degrees east. Wrong bird.
Edited by uglyned
thanks for the reply,
I have tried to scan that one but it keeps freezing, it gets as far as this (below) then stops and I have to ctrl alt del to shut it down
If I try to scan it from dvb I end up with this..
but all I get are spanish channels no english at all.
Why do I have a list of 50,000,000 ini files for foreign tv? I only want English and HD?
Is there a step by step guide for receiving only English and HD channels?
Regards,
Tripitaka
Where ist your dish pointed to? Astra19,2° or Astra28°? This is the first thing you must know, if it isn`t pointed to the right direction, you can scna 100 tmes and you can`t find any channel you are searching.
PeterF
:wacko:
Yes you are correct of course. The foundations must be good for the structure to be sound.
So today I refreshed my pc, updated .net and did a full uninstall/reinstall of programmes and codecs.
Scanned the Astra28 and bingo, High Definition :rolleyes:
I do have a couple more questions though, which is the best Video Rendering setting? and Where do the freesat tables go?
Thanks for the advice.
