uglyned Posted March 21, 2010 Posted March 21, 2010 Hi, I'm thinking about buying a Bluray drive but I want my HTPC to remain as simple to use as possible - no using Windows or transferring between applications. So if I do get a drive, I'll need DVBViewer to play the discs. Can DVBViewer handle Bluray? Are there any known problems?
desweil Posted March 21, 2010 Posted March 21, 2010 It can handle non copy protected discs. So if you want to watch movies on bluray you have to either rip them with some illegal tool and play them from HDD, or use software like PowerDVD/winDVD. They can be "integrated" into DVBViewer with a tool "DVBViewer Switch". It opens Powerdvd automatically and plays back the disc, DVBViewer is then in Background and TV is stopped. When you close powerdvd, DVBViewer get focus again and tv is restarted.
SnoopyDog Posted March 21, 2010 Posted March 21, 2010 (edited) The other thing is, DVBViewer still can not show subtitles from Blu-Ray material. So films like "Dancing with the wolves" would be complete mystery Edit: On the other hand, i like to have all the functionality in one program, one look-and-feel... Edited March 21, 2010 by SnoopyDog
foefelken Posted November 2, 2010 Posted November 2, 2010 It can handle non copy protected discs. So if you want to watch movies on bluray you have to either rip them with some illegal tool and play them from HDD, or use software like PowerDVD/winDVD. They can be "integrated" into DVBViewer with a tool "DVBViewer Switch". It opens Powerdvd automatically and plays back the disc, DVBViewer is then in Background and TV is stopped. When you close powerdvd, DVBViewer get focus again and tv is restarted. Where is the download-link to the tool ? I cannot find it.
foefelken Posted November 13, 2010 Posted November 13, 2010 Or use AnyDVD HD. Using AnyDVD HD does not solve the problem of playback from BD-discs or rips from within DVBViewer ! The only thing AnyDVD HD does is removing the copy-protection and ripping of the disc. In MCE the switching between PowerDVD (and MCE) is possible. But as we all know, MCE sucks
desweil Posted November 13, 2010 Posted November 13, 2010 in DVBViewer, the switching is also possible. Either via "DVBViewer Switch" (including fowarded keyboard/Remote commands and switching of grafic profiles for 24hz etc.) or for example with selfmade Evenghost makros.
dvbrewer Posted November 13, 2010 Posted November 13, 2010 Either via "DVBViewer Switch" Do you have the link for DVBViewer Switch (foefelken asked for it above)?
foefelken Posted November 14, 2010 Posted November 14, 2010 Hi dvbrewer, I think that i found it. The link to the topic : Link However, the explanation is in german. For me its a "wartaal" (also for google-translation) I did not test it yet. If you intend to, please let me know the results.
desweil Posted November 14, 2010 Posted November 14, 2010 The english description is included in the "DVBViewer Switch.pdf"! see first Page of the Thread.
galmok Posted November 14, 2010 Posted November 14, 2010 Using AnyDVD HD does not solve the problem of playback from BD-discs or rips from within DVBViewer ! The only thing AnyDVD HD does is removing the copy-protection and ripping of the disc. Do you have personal experience with this? I do have AnyDVD HD but no Blueray drive yet so I can't test this, but the feature of AnyDVD HD is to decrypt the disk before the application (whatever application) can see it. DVBViewer should see the disk as a normal unencrypted blueray disk and offer to play it normally.
Pynkyz Posted November 14, 2010 Posted November 14, 2010 Well, I do playback BR directly from DVBViewer with AnyDVD HD. If I insert a BR disc in my BR drive, and DVBViewer is running, the latter prompts me if I want to play it back, and in case it starts playback from the point I interrupted watching earlier. You don't get the interactive menu, and the subs, but you can choose the audio and skip back an forth with no problem. Pics: 1 and 2
foefelken Posted November 14, 2010 Posted November 14, 2010 (edited) Do you have personal experience with this? I do have AnyDVD HD but no Blueray drive yet so I can't test this, but the feature of AnyDVD HD is to decrypt the disk before the application (whatever application) can see it. DVBViewer should see the disk as a normal unencrypted blueray disk and offer to play it normally. @Pynkyz : thanks for the info & pics ; its a pitty that the subtitling does not work. Maybe something for version 4.6 ? @Galmok : yes i have experience with AnyDVD HD. It works fine. Deleted Edited November 14, 2010 by Griga
foefelken Posted November 14, 2010 Posted November 14, 2010 The english description is included in the "DVBViewer Switch.pdf"! see first Page of the Thread. Hello desweil, Thanks, i know. But there wend something wrong when i first downloaded the file. The pdf was unreadible. Yesterday i downloaded it again an now it works fine. By the way : is it up-to-date ?
Griga Posted November 14, 2010 Posted November 14, 2010 Sorry, it's going a bit too far and becoming too AnyDVD specific here. So I have to stop and close this discussion, because we don't want to get accused of supporting copyright infringement (which can happen quite easily in Germany). Please continue the discussion in another forum or privatly.
