DVBViewer and TBS 8920 (S2) Diseqc Problem
mydan
Hi there,
I bought DVBViewer last night - recommended by my DAD :) He has a Hauppauge Nova S2-HD which worked perfectly a 2 port diseqc switch which he gave me.
I bought the TBS 8290 S2 card though (For no other reason than it was cheaper!) I have a simple two LNB setup on one dish - one at 13E and one at 28E). My satellite receiver swaps between port 0 and port 1 easily.
I did a search on the forum and a guy reported something similar - but it's a different problem I have, I think. 28E is on port 0 - which will scan and find 804 channels using POS A OPT A. When it comes to trying to scan Hotbird on port 1, using POS B OPT A, it finds 103 for BSkyB, POS A OPT B find 92 channels, all BSkyB and POS B OPT B finds 92 all bSkyB, but I am sure yesterday when I did a scan or two I found a few (only around 60 or so) CYFRA+ channels. Today I can't find any.
Further info:
WIndows 7 x64
Latest TBS 8920 Driver - 1.0.5.3
Chipset: NVIDIA nForce 590 SLI AMD - Latest NVIDIA nForce Driver
Graphics: NVIDIA 9500GT - 8.17.11.9621
Can anyone advise me what to do to get it working - if at all?
Thanks
Dan
What about TransEdit (installed according to your support.zip)? Same problem?
hi there,
Equally unpredictable unfortunately. However once, after having tried most DISEQC options first, I tried selecting NONE and I started getting hotbird results in right from the first frequency. So immediately I thought "Great, Sky is Simple A / POS A OPT A, and Hotbird will be None. But closing Transedit and reopening and choosing None didn't find anything second time around. I have yet to get it to show them since.
A little painful this one!
Dan
None means no DiSEqC command at all. Strange... the options that you have tried before must have switched to Hotbird.
Maybe it's a communication problem between the DiSEqC switch and your card, or a timing issue... sometimes cases like this can be handled by using the DiSEqC Editor (also available in DVBViewer Pro). Set DiSEqC to "Extended" and enter something like
Switch - Committed - 2
Internal - Delay - 500
which means, the DiSEqC command for B/A will be sent twice with 500 ms delay in between.
Now you have to pay in a different way... it costs a lot of time.
The Switch, Delay Switch, didn't work. But as it made me understand the function of Extended, I tried a few others - Switch 2, Switch 2 (Uncomitted each time) with no delay made it work flawlessly.
So it found 1623 channels on Hotbird.
And DVBViewer swaps between both flawlessly.
PERFECT support Griga. Many many thanks :)
