Dvbserver - signal
goofyhsk
When running DVBServer only on the server,
DVBViewer on the client
Is it possible to get realtime signal passed through to the client??
As far as I can see it always says 100% on the client as it's seeing 100% connection to the server - as opposed to 100% to the channel signal
This is not available with the DVBServer. It's available with the recording service.
OK thanks,
I've installed recording service, but I can't connect to it at all on other pc
Tried vista compatibility mode, but no go
what programs (if any) do I have to add to my firewall exceptions?
i did follow that guide (ok, i missed the alternate port bit - but i did try about 5 different ones)
adding dvbvservice to firewall exceptions seems to have worked
EDIT:
yay, i can see how bad my signal is
Edited by goofyhsk
what determines which tuner the recording service uses??
..you can assign different priorities in the RS. The preferred device will be used 1st.
