ProfTuners Posted March 26, 2010 Posted March 26, 2010 http://www.prof-tuners.com/download/soft_p.../ProfRemote.dll Version 1.0.0 Installation: Copy the file to the directory ProfRemote.dll Plugins Connection: "Settings", "Options ...","Input","Inputplugins","Prof Remote" Education: "Settings", "Options ...","Input ","Learn" The latest beta viewer on training buggy and under certain circumstances fall. Look carefully. Supported hardware: Prof Red Series DVB-S2 7300 PCI Prof Revolution DVB-S2 7301 PCI Prof Revolution DVB-S2 7500 USB Prof Revolution DVB-S2 8000 PCI-E Quote
yallawo Posted March 26, 2010 Posted March 26, 2010 hey! thanks for this plugin. now DVBViewer can learn remote strokes and commands but i think it has some bugs windows xp crashed 3 times when plugin is active. Quote
ProfTuners Posted March 27, 2010 Author Posted March 27, 2010 (edited) now DVBViewer can learn remote strokes and commands but i think it has some bugs windows xp crashed 3 times when plugin is active. 1. You will have problem with beta-version. Pls, use stable version of DVBViewer Pro (Version: V4.2.1). 2. You will have problems if you use more than one DVB-card in one PC. DVBViewer has no decision of this problem. It has confirmed Lars in this thread: http://www.DVBViewer.info/forum/index.php?showtopic=39606 Edited March 27, 2010 by ProfTuners Quote
shansi Posted March 27, 2010 Posted March 27, 2010 (edited) now DVBViewer can learn remote strokes and commands but i think it has some bugs windows xp crashed 3 times when plugin is active. exactly..i have DVBViewer pro 4.2.1 and i have this problem.(prof 7500 usb2,win 7 ultimate) Edited March 27, 2010 by shansi Quote
ProfTuners Posted March 27, 2010 Author Posted March 27, 2010 (edited) now DVBViewer can learn remote strokes and commands but i think it has some bugs windows xp crashed 3 times when plugin is active. This proposal does not contain any information. 1. Operating System (XP SP2 or XP SP3 or Vista SP2 or Win7) 2. Architecture - 32bit or x64 3. Version of DVBViewer Pro 4. Driver Version 5. The system has other connected DVB-Cards 6. What a load CPU? Which codec is MPEG2? Which codec is MPEG4? 7. Do you have updated drivers for your motherboard and installed all the updates to your operating system? 8. Another additional and useful information. Prof Prof-7500 USB: Your problem may be in the driver for the USB. Have you updated the USB driver to the last, which offers the manufacturer of your motherboard? And do not forget, the recommended hardware configuration for satellite TV to any DVB-cards: Windows XP SP2/SP3, 32-bit architecture. We use this architecture and will never have problems. P.S. x64 - in this architecture, applications run in emulation. Therefore, always x64 will have problems. This waning architecture PC. P.P.S. Windows 7 is still raw system. Bugs will be fixed in service packs. P.P.P.S. But I think everything will work well, and on Windows 7 x64, for those users who have installed all the updates and the latest drivers for operating system and have a low percentage loading of CPU. Edited March 27, 2010 by ProfTuners Quote
shansi Posted March 27, 2010 Posted March 27, 2010 My driver is up to date. Before worked by skystar hd2 and work ok.i changed to prof 7500 usb2 i changed win and my codec in CorAVC Pro 2 Cpu 3.4 core2 Ram 4G VGA 9500GT Win 7 32bit DVBViewer Pro 4.2.1 but my Viewer crashed when plugin is active(when inactive good work) Quote
ProfTuners Posted March 27, 2010 Author Posted March 27, 2010 Ok, thanks. But you did not answer the key questions: 1. Has the system other connected DVB-сards? 2. Have you updated the USB driver to the last, which offers the manufacturer of your motherboard? CoreAVC 6. What a CPU load? I think that your Windows is not enough resources to play H.264 HDTV video with CoreAVC codec + CPU. Quote
abodd Posted April 3, 2010 Posted April 3, 2010 http://www.prof-tuners.com/download/soft_p.../ProfRemote.dll Version 1.0.0 Installation: Copy the file to the directory ProfRemote.dll Plugins Connection: "Settings", "Options ...","Input","Inputplugins","Prof Remote" Education: "Settings", "Options ...","Input ","Learn" The latest beta viewer on training buggy and under certain circumstances fall. Look carefully. Supported hardware: Prof Red Series DVB-S2 7300 PCI Prof Revolution DVB-S2 7301 PCI Prof Revolution DVB-S2 7500 USB Prof Revolution DVB-S2 8000 PCI-E Thanks for sharing your knowledge for prof DVBS2 RC Best Regards Prof Iran Distributor (www.dvbs2.ir) Quote
ProfTuners Posted April 28, 2010 Author Posted April 28, 2010 BTW, We started sales of Revolution 8000 PCI-E DVB-S2 + Low Profile: http://shop.prof-tuners.com/?id=231&item=55 Quote
finalweb Posted June 12, 2010 Posted June 12, 2010 Anyone has this problem? I have Windows XP + Prof 7500 USB + DVBViewer 4.2.1, copied the file ProfRemote.dll to plugin directory, have selected in "Settings", "Options ...","Input","Inputplugins","Prof Remote". HOWEVER, under the each function entry under "Settings"->"Options ...","Input ", there is no 'Prof Remote', only 'Keyboard' is shown. Thanks for your help in advance. Quote
instl Posted July 2, 2010 Posted July 2, 2010 My OS: winxp sp3 ,and found a serious bug, Click button learning, to exit the DVBViewer, confirmed that there is ProfRemote.dll bug. Can update addresses, please? Thank you. Quote
ssaudrius Posted September 29, 2010 Posted September 29, 2010 nothing cant learn.i can set setingns Quote
