Latest beta can't display Chinese EPG correctly by Xepg
ter9999
Sorry to start a thread here with the 4.3 beta version of DVBViewer problem.
The latest beta (.90) can't display Chinese EPG correctly imported by Xepg:
I attached the support.zip and epg.dat/channellist/original XML file imported by Xepg as attached. Please check CCTV-1 (ch. 63) for this issue as I used in the snapshots.
more.zip
Are you using Xepg 0.3.2.2 Unicode TESTVERSION or Xepg 0.3.2.1 beta ?
Hope that by improving the support for Simplified Chinese.THX!!!
This source code part hasn't been touched since several betas. Maybe a problem with the datasource?
Okay, after installing the latest Xepg 0.3.2.2b and set Character set to "OEM_CHARSET" (very important), the Chinese characters display correctly.
Thanks very much!!
