robena Posted March 28, 2010 Posted March 28, 2010 (edited) Hi, The size of the Start and End fields in the timer windows is too small, you can't read the full time. Please see the attached screen cap: Thanks! Edit: oops, forgot the support file. Here it is. support.zip Edited March 28, 2010 by robena Quote
robena Posted March 28, 2010 Author Posted March 28, 2010 Here is the support file. support.zip Quote
Tjod Posted March 28, 2010 Posted March 28, 2010 You are using Version 4.0.0. Do you have this problem in Version 4.2.1 as well? Quote
robena Posted March 28, 2010 Author Posted March 28, 2010 (edited) Yes, it's the same with 4.2.1. It's the PM display that takes too much place. If I go on an existing reservation, PM is not displayed and I can (for example) see "18:29". But I try make a new recording, I can see a field like "_7:PM". These Start and End fields should a bit wider I think. Edit: or the PM display should be dropped. It's useless since DVBViewer uses anyway a 24 hour notation ("18:29", and not "06:29 PM"), at least on my PC. Edited March 28, 2010 by robena Quote
