4.2.1 cannot tune to ITV HD
robena
ITV HD is on Astra 28.2, but the stream is obfuscated, so you have to enter the following parameters manually:
Video PID 3401
Audio PID 3402
Video Type H.264
Audio Type AC3
PCR PID 3401
PMT PID 3400
This works perfectly with 4.0, but with 4.2.1, as soon as you try to tune to ITV HD, you only get a blank screen and when you go back to the channel editor, you see that the video PID has changed by itself to another value.
I forgot to mention the tranponder in use:
31=11428,H,27500,23,1,|Arqiva
and the card is a Technotrend S2-3200 HDTV-S2.
..no problems here. Check the StreamID and SID
By reading your file, I searched for 10510 in the scanned channels. I found it in the audio section, and by modifying the PIDs, I got the video too.
So, making from scrap does not work, but modifying a found audio channel does.
Thanks!
