Guest DAvenger Posted May 14, 2004 Posted May 14, 2004 Don't ban me because I did not search the board for a solution. Just installed Windows 2003, drivers (without the Technisat thing). Do I need anything else? Cos it's not working (with neither one of the sourcefilters). Marfi says B2C2 card not detected, DVBViewer filter is siltent and blank Thanks Quote
Guest Oliver Posted May 14, 2004 Posted May 14, 2004 Well, you should follow this guide: http://www.msfn.org/win2k3/ After that you should be able to use the DVBViewer. Bye, Oliver Quote
Guest DAvenger Posted May 14, 2004 Posted May 14, 2004 Already did that. Maybe it only needs a reboot? Quote
Guest DAvenger Posted May 15, 2004 Posted May 15, 2004 Still no luck Using DVBViewer sourcefilter, tuned CNN and the viewer entered "radio mode" (definitely a bug) and the signal strength is going from 260% to 10% and back. Quote
