One channel RTL8 can not be recorded
Hello,
I have a problem. I can not record the programs from channel RTL8 anymore. The transmission is only 0,001 mb/s.
When I start DVBViewer i can see the program correctly.
Can you help?
Regards,
Jan.
Do you have this problem only with encrypted channels?
RTL8 is a encrypted channel. But also some other channels are encrypted for example RTL4, and that is working correctly.
Sounds like a problem connected to the cam.
Sounds lice a problem connected to the cam.
It is strange that the problem not exist in DBVviewer then everything is working correctly.
